Redsky
Jun 07, 2014Explorer
Both are equally good. Honda has a generator with a 30-amp receptacle built into it which is handy and the provision for easily adding an external gas tank for longer run time without having to add fuel to a hot engine. Yamaha has at least 5x as many dealers that are able to service a generator if there is a problem or needs servicing of any type.
First determine how much generating power (peak and operating) and then size the generator that is needed. I would sooner buy a 200, 2500 Watt or 3,000 Watt single generator than two 1000 Watt generators though the weight may be more than I want to lift with a single higher capacity unit.
Both types are going to be quieter than the average generator and safer to use with electronics attached.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: Sep 14, 2016
