Atrain217's avatar
Atrain217
Generator help PLEASE!
Hello all, I appreciate any and all help in advance.
Long story short, Camping World never changed the oil on my generator even though I asked them to and my generator (Cummins Onan RV QG 4000) ran out of oil and is kaput. Obviously I need a new one soon. Do I really need to buy the same generator to the tune of $2900+ or can I buy something else that isn't as expensive)? If its the latter, will you please recommend a comparable one that can be turned on/off with the switch inside the cabin, run on the propane, etc.... basically the same functions as the stock generator.
Also, is there anything I can/should do with the dead one? I'm considering a civil suit against Camping World.
My RV is a 2017 Forest River Georgetown 31B3.
Thanks again!
    Did it run TOTALLY dry and the engine seize up? Most gens have a low oil cutoff switch to stop the engine before damage occurs. I would try adding some oil and then try to starting it.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
