Adamgre's avatar
Adamgre
Generator issue
I'm sure this has been asked and explained 100 times but I can't seem to find an answer for my problem.I've got an 86 Minnie Winnie with a Onan Emerald I Genset. Rv was recently purchased and I've had the generator running and seemed to be perfect. The fuel level may have gotten too low to run the generator but I've since filled it up. I've had the fuel pump out and checked it on a good battery and it ran like it should then. When I take fuel line off of pump and try to start it no fuel is coming out, I'm gonna get a meter and check to see if I'm getting power to the pump but if I'm not then where would my problem lie? Also should fuel run out of the line to the generator? I don't have any coming out so I tried to trace the line, it seems to run to the carb? Is that correct? I figured it would go to tank but doesn't seem to. Thanks for any help In advance
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Mar 13, 2017
