I'm sure this has been asked and explained 100 times but I can't seem to find an answer for my problem.I've got an 86 Minnie Winnie with a Onan Emerald I Genset. Rv was recently purchased and I've had...
When I needed to give my generator a shot of carb cleaner I didn't want to dilute it with all the gas in the tank. I put gas in a gallon can then added the cleaner. Ran a hose from the can to the intake of the pump. It sounds like your problem may be a bad hose, cracked, making the pump suck air instead of fuel. If you try this application and the genny runs, that would pretty much show the problem is from the tank to the pump... Just a thought.... Good luck..
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
