Gdlow
Aug 13, 2013Explorer
eabc5454 wrote:
Hello:
I have an Onan QG4000 generator that is due for its first oil change (20 hours). I have the owner's manual, and while it lists the correct oil based choices on temperature, it has no discussion on synthetic oil. I actually called Onan, and they said the owner's manual tells you what oil to use. Well, yes, it tells me viscosity, but not whether synthetics are OK.
So, here are my questions for those of you who are far more knowledgable than I:
Is it OK to use sythetic oil? If so, is there any benefit in doing so?
Thanks!
I actually had an Onan rep. at one of the big FMCA rally's recommend using a synthetic (mobile 1) in the correct viscosity... but I am sure either is fine...
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
