- MrWizardModeratorDon
That magnum is real nice
But for the money he can buy a 3000ui and have cash left over - pianotunaNomad IIIAdd a hybrid inverter/charger which will take care of the start up surge. Then you have a fighting chance that the Honda 2k unit will operate the roof air.
- naturistNomad IIif the stars align just so . . . maybe. Mostly, though, the answer is no.
And you, OP, are right, it has been asked a thousand times. At least. - IvylogExplorer IIIStart it NO
- azrvingExplorerHere and there you will hear someone say they are doing it and it then gets into hard start capacitors etc. I run my 13,500 on a Honda eu3000si and it does fine. My coachmen owners manual said use 4,000 watt gen. They are giving more cushion as people do when they say get an inverter that is bigger than you need so you are running it at a lower point in it's operating range. You know, so it's not flat pedaled all the time. :)
- TrackrigExplorer IIAccording to the data sheet that came with my 13.5A/C (a Coleman Mach 3 on a 2007 Nash 26X trailer) it draws 1,560W on standard and 1,960 on high. I just got the trailer and haven't tried it on my Honda's yet, but I don't think one of them will do it.
Bill - csamayfield55xExplorerI had a carb issue on my eu2K, pulled it apart and set up on my trailer for a test run. Let them for a couple of hours just to check while I was in the house. AC was running pretty well. One of them ran out of fuel before the other and I didn't catch it. The other one was tripped on OL when I got out there. Put fuel in the empty one and restarted all. Everything came on just fine. You need 2 to run the AC.
My trailer has a pair of 13.5K AC's but there was only 1 running and nothing else.
I have ran a Coleman 13.5AC in an old KZ for an entire weekend on a single EU2K
Chris - 2oldmanExplorer IINot for long. That's working a 2kw pretty hard.
- LwiddisExplorer IIRun it? Probably. START it? Probably not. And if it doesn't start the A/C...
- Borderline!
If your converter has charged the batteries and very little load, it may start it. Make sure that it is not started under load. That is the AC is off, genset started, warmed up.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 11, 2025
