beemerphile1 wrote:
Beerlord wrote:
Thanks for the honesty! Like I said, I'm new to the rv/trailer scene. What db rating should I be looking at? And is 2k watt enough power or should I look for something bigger?
If you have a 30 amp RV that is the same as 3,600 watts.
A 2,000 watt generator most likely will not run your air conditioner without modifications.
Many use two 2,000 watt generators and pair them together with a kit when needed to run the A/C.
For anything other than generic answers create a profile or signature line detailing what you have. When asking tech questions the more info you can give is better. For instance, how many BTU is your A/C unit?
Thank you! I thought about running the 2 2k gens paired. Plus they're a lot easier to carry! I'm working on the signature line now. I am a newbie, so I'm sure Ill have a ton of questions. I'm hoping people like yourself to offer up real life experiences. Oh and the AC is 13.5k :)
