chefdc1's avatar
chefdc1
Generator will not stay running
I have a Kohler Confidant 4 Generator in a 1997 (Ford V10) Damon Hornet Class C. The gen will not stay running. I have plenty of gas. Oil is full (could probably be changed). Spark plug is fine.
It will start, but wont stay running. If I hold the switch on (either in the coach or on the gen) it will stay running but quits when I let go.
Any ideas?
Thanks!
  • My genset has given me problems throughout the years. They have included:
    Inability to start or stay on when it is very cold.
    Didn't start at all due to a bad fuel pump.
    Didn't start due to being at 3/4 or less of a tank of gas.
    Wouldn't start due to bad plug or oil, which was solved by taking it in for a major service.
    I did read recently on another forum about someone whose genset would cut off intermittently due to the voltage regulator being bad.
    Best of luck in your quest.
  • Sounds like a fuel pump going bad. You could rig up a small container to gravity feed the generator and see if it stays running.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
