- Harvey51Explorer
As if you dry campers didn't know exactly how long you can go without dumping without looking at the gauges.
Yes, one gets to know the duration and signs. We know we need a dump every 4 or 5 days. - Ralph_CramdenExplorer II
jplante4 wrote:
Dutch_12078 wrote:
jplante4 wrote:
E - don't worry, be happy. Just forget about the levels. Dump the gray tank when it backs up into the shower. Dump the black tank when you start to smell it.
Yep, that would be just perfect for that 6AM bathroom wake up call and you're on a no sewer site. ;)Ralph Cramden wrote:
Exactly. Or if you search out the electric only or undeveloped sites in state parks or ACOE/Fed campgrounds like we do. When you're on night number 7 of a 10 or 11 night trip its nice to know if you can make it to night 11 without making a trip to the honey hole with the blue tote.
I guess we would know exactly after enough dry camping with the same people or number of people, eating the same diet while consuming the same amount of liquids, and if we took the same amount of showers timing them to the split second along with measuring out the water used for doing dishes and such, but that seldom happens. - down_homeExplorer IIOurs have worked fine since day one.
We do flush our tanks, and not just drain them. That may contribute to good performance.
Fill three quarters or less full and all the ice cues you have. Put some water softener and dish soap into the mix and drive down a bad section I40 or somewhere.
Bleach will also cut grease and crud too so pour some of that in.
Flush don't just drain and refill and flush all the soap etc out again.
If that don't do it, well I haven't replaced any sensors, or checked wiring.
I do understand, I believe there is not a whole lot to the sensors to go bad.
So maybe the cleaning will do it.
Now I'm gonna sit back and watch someone tell you and me how to fix it right. - ncrowleyExplorer III had the Sea Level II system installed recently and we really love it! In our case, the sensor was on the wall of the tanks and they were coming loose.
- jplante4Explorer II
As if you dry campers didn't know exactly how long you can go without dumping without looking at the gauges. - lanerdExplorer IIOk, lots of different remedies here. Some good, some bad. So, I'll add my 2 cents.
I've owned several different types of rv's from pop-ups to our current mh. What I've always done to keep my tanks clean and in perfect operational condition (including my sensors) is this:
When getting ready to travel, I'll dump both tanks and rinse the black with the in-tank rinsing device. If you don't have one, I suggest you have one installed (fairly easy job). Then I'll dump again and add about 5 gallons of fresh water along with a cup full of liquid laundry detergent (I use Oxy-Clean) in both tanks. I'll then drive to my next destination and once there dump the soapy solution from the tanks and add several gallons of fresh water and use the tanks normally. The next time I travel, I repeat this process. If you can get your hands on some liquid Calgon water softener, add a cap full, or two, along with the cup of detergent. The Calgon will make the inside of the tanks slippery...hindering anything sticking to it (or the probes).
Keep in mind that water, lots of water, is your friend. When either using the toilet or dumping the tanks, use lots of water. ALWAYS keep water in both tanks....never let them dry out.
Again, this is my proven solution that has worked for me for years and years. It will even keep the odors down so that no black tank chemicals is required...ever.
Like I said... my 2 cents. Take it or leave it.
Ron - myredracerExplorer IIBest way to clean? Liquid Drano. That's what our KZ owners manual says to use. It won't hurt metal or plastic, including the seals. We use it from time to time to get the tanks back to factory fresh condition. Have used it for the 3 prior seasons. Problem is, it doesn't take very long before the sensors aren't working again. :(
The Horst Miracle probes may or may not help and it depends somewhat on the shape, dimensions and location of the outlet pipe. They worked great on a previous TT but hardly make a difference on our current TT.
After you've been using your tanks for a while, you get to know about when they need dumping. Looking down the black tank works - adding a shutoff valve behind it helps. - Dennis12ExplorerCompletely fill grey and black tanks, Hot water if possible, overdose it with Dawn dish liquid. let set overnight. Buy a Valterra A01-0187VP Flexible Tank Wand by Valterra $ 16 95 Amazon. Drain tank. On the open black tank drop the wand turned on high slowly down the commode slowly spinning it. take it down as far as you can even till you do not see it and you are spinning it by the hose. Do not be in a hurry, let it blast the tank. Now drain the grey tank and do the same thing but go into the dump opening. The statement above " to use septic safe toilet paper as it breaks down easier in the tanks and is less likely to wrap around or attach to the sensors." I don't agree with. If you take any brand of toilet paper and put a sheet in a glass of water and let sit overnight it will be like mush when you try to pick it out.
I have put the Seelevel system on every trailer we have owned, and have found it's better than sliced bread. - Dutch_12078Explorer III
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
