ScottG
Apr 25, 2017Nomad
Based on what I've read here and found with my own TT's, I think the biggest issues you may find are:
Distance from coils of fridge to back wall incorrect.
No slope to roof vent. Just a flat ceiling with a hole in it - air doesn't move efficiently through vent. Instructions tell you this should be sloped to direct air movement up through vent. You can use sheet metal to form a chimney.
Roof vent partially blocked by rubber membrane material. Mine was appx. 60% blocked. They cut an "X" in the material over the vent hole and staple the sides. This left a lot of rubber sticking out into the opening.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
