rerod's avatar
rerod
Glazing bead useful life? reoccurring leak
Iv had a reoccurring window leak. Iv removed the window three times. The first time, it had the factory silicone which was replaced with good butyl tape which looked good the next two window removals. The last time I removed the window I removed the glazing and found some mud blocking the weep hole, so I figured I had found the underlying issue. But a few weeks later, I still have wet interior paneling! Thank god I have a aluminum trailer!
Anyway, I'm beside myself right now because I again removed the glazing to find its still clean under it and I'm sure the butyl is doing its job sealing the window to the trailer.
What is the life span of window glazing? And is that the only thing which could allow water in since I'm sure the window is sealed to the trailer?
I'm just about ready to trade my trailer in for a tent!
Thanks!
  • The infiltration point might NOT be where you think it is.
    It might be above or to either side.
    This might be a case where a few dollars to a professional RV body shop would be well spent.
