jchonroad
Apr 18, 2014Explorer
GM Ignition Sensor Fuse
I just installed a remote switch in my 2012 Malibu for the "Ignition Sensor" fuse. (Needs to be pulled for towing, per the owner's manual.) It doesn't seem to make a difference whether the fuse is "in or out", the car starts and seems to run just fine. Are there any GM experts on here that can explain why that fuse needs to be pulled when towing, or did I screw up when installing the switch. I have the same setup as the Roadmaster remote switch, except I went to Radio Shack and paid WAY less for all the parts and pieces. Thanks
