Wingcamper's avatar
Wingcamper
going into Canada with treated wood steps
My wife recently had a knee replaced and is struggling with the 5th wheel steps, so I went to the lumber yard and bought treated lumber and built her some steps. The steps lay in the bed of the truck when traveling. We are crossing into Canada from Michigan in 3 weeks. Will I have a problem with this at the border check station?
  • You're fine. Rule applies to firewood. They don't want our pine Beatles or whatever.
  • I think it is only firewood that's a problem. But country of origin would not matter, nor would it matter how much treated wood canada uses. Not the point. If there was one.
  • Pressure treated wood is used on nearly every deck and many other applications all over Canada. Can t see any problem for your steps.
    Fyi
    They sell treated lumber in every hardware store in Canada,,some of it imported from US..
    I wouldnt worry..
  • Firewood is a no no but never had a problem with taking finished lumber across the border.
  • If you can't take treated steps, then you better take out the woodwork, that is just sprayed with paint or laquer.
    Leave the wooden leg at home too.
    Show them the DDT bottle you sprayed the wood with. That ought to do it.
  • You can't bring treated wood steps into Canada? I don't know the laws. What's the reason?
  • Put the steps in the trailer if possible - out of sight, out of mind.
