- RinconVTRExplorerLOL...now the Westlake failures come out of the wall.
Let's be clear. I did not say there were not ANY failures, I said they are "not common".
Meaning, I can find more reported failures online of most other popular options than I can Westlake brand, by a long shot.
I have never had an ST tire fail, but that doesn't mean anything. That's just my luck. There's not a tire on the road that hasn't failed. - NC_HaulerExplorer
Old-Biscuit wrote:
I have Goodyear G614s on my 5vr........OEM tires
At 3 1/2 yrs had blowout that did $3500 damage to 5vr.
Goodyear DID cover the damage costs and new tire....but it cost me Hotel Room 3 days as we were FTng while 5vr in factory for repairs.
Did replace those with another set of Goodyears because they did pay for the damages AND not much else was available in that size and load rating at the time.
NOW>>>>>>>
I am going to give the Sailun S637 a try next set of tires.
'G' Rated alternative 16" tire vs Goodyear
4,080# Max Load Rating at 110 psi (Goodyear G614s---3750#/110 psi)
Good reviews............and lower price point
Ditto:..I've read more bad reviews on the Westlakes than the G614's...I will replace the new Westlakes on my TH with the much much higher Quality Sailun S637 tires... They are quite a bit cheaper in price compared to the G614's....and I've not read the first negative on the S637's...some reports going back 3 years or so....The G61`4's are great, but it's nice to have a cheaper priced tire and the company be ISO, TS 16969 compliant.....speaks volume for the tire.
Jim - HelmseyExplorer
RinconVTR wrote:
I would have no fear running Weslake tires on any trailer. In my research over many years, they have a great reputation and its not common to find a reported failures. There are far more (easy to find) reports of the G614's failing.
I find it very odd you did not feel comfortable with Westlakes because you are nearing their capacity...whatever that means. 80%? 90%? Do you even know? And they have a larger "bulb" where the rubber hits the road, which means what exactly. Its more prone to fail if it has a certain size bulge? Good tires do not bulge at all?
Those are very unprofessional and unwarranted perceptions, even for an internet forum.
TPMS gave no warning before the Westlake let go. I opted not to use the same tire when replacing these 4.
- 1ofmanyExplorerWe have run our G614s over two years without incident...happy with them so far.
- Old-BiscuitExplorer IIII have Goodyear G614s on my 5vr........OEM tires
NOW>>>>>>>
Good reviews............and lower price point - TucsonJimExplorer II
Here's a reported failure for you:
I had the tread come part way off of this Westlake tire at approximately 7,000 miles. I was traveling at 64mph and never exceed 68mph, even though this tire is L rated for 75mph. The manufacturing date was 4914. The TPMS did not detect a low pressure or over temperature event. The tire was still fully inflated and reading 85psi (hot) at the time of separation. I incurred approximately $3,000 in damage to the underside of my FW when this occurred. I'll make it clear that the reason for failure is unknown, and may in fact be related to something that could have happened after the tire was put in service. But it failed, and did damage to my rig, so I'm wary.
I contacted Lions Head tire and wheel in Indiana who is the U.S. distributor for Westlake. I never heard back from them.
Up until that time, I had very good success with Westlake brand. However, you can not simply go to your local tire store and purchase a new set. You must try to find a distributor, purchase them, have them shipped to you, and then have them mounted.
So I started my research, and after many hours of analysis, I went with the Goodyear G614 LT tire. It is a name brand with a reasonably good reputation, and you can find a replacement in pretty much any large town in America. - peaeye1ExplorerThose are very unprofessional and unwarranted perceptions, even for an internet forum.
I am not a perfessional and I have no warrants. [ That I know of].Well, there was a little trouble up in Oklahoma, but we don't speak of that much.
:) - peaeye1Explorer
TucsonJim wrote:
I just replaced my Westlake tires with the same Goodyear tire you did. I'm looking forward to hitting the road with a little more confidence this summer. By the way, did you file for the $20 per tire rebate? It runs from 4/1/16 to 7/31/16. Here is a link in case you missed it:
Goodyear G614 Rebate Form
Jim
Thanks Jim, I will ck into this. - peaeye1Explorer
ummmm ok, thanks.:R - RinconVTRExplorerI would have no fear running Weslake tires on any trailer. In my research over many years, they have a great reputation and its not common to find a reported failures. There are far more (easy to find) reports of the G614's failing.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 21, 2026
