2014MegaRam4x4's avatar
Feb 09, 2015
Goosebox hitch installed
Hello all, I needed some extra room in my bed of the truck and wanted to do away with the Dodge factory Picture frame adapter and reese hitch to make a little room for my 60 gallon Fuel Cell / Toolbox combo. So I wanted to share some photos and give some feedback on the Reese Goosebox that I installed over the weekend. The install went relatively simple, removed the 10 bolts on the original pin box, and it slid right out it's not too heavy about 40 Lbs, easily managed with 2 people. The only challenge of the install of the Goose box is the wight (150lbs) and awkwadness of the size. The two of us lifted it up and installed one bolt each side to hold it in place. Once in place is was a whole lot more manageable and bolted up the 6 of the 8 required grade 8 hardware bolts (3 per side), it's just getting it up and holding in place to slide bolts in to hold it that's difficult, but this can be overcome easily with more people. We could only put 3 bolts in as one of the holes was off on each side and we had to drill the through the frame using a 13/16 drill bit to allow the bolt to fit. Outside of the need to drill and the weight there was no issues at all and the total install time was about 3-4 hours.
The ride felt like it was an improvement, as there appeared to be less chaulking and bumping coming from the trailer transferred into the truck frame as the hitch airbags that are built in holding 50 PSI appeared to be doing what they were designed to do.
I can say it was an all around good investment, allowing me to increase my traveling range and easy access to necessary tools in the invent something happens. Oh yeah and no more struggling with lifting in and out about the 200 lbs of the adapter and hitch into the bed every time we went somewhere, now it's just a drop in gooseneck ball, connect the 2 chains and were rolling!!!!
Moderator edit to re-size pictures to forum limit of 640px maximum width.
  • Nice. Good to know there are some trailers that are strong enough for a goose neck.
  • Welcome to the "dark side".
    I've had my Reese Goose Box since we bought our Sundance and have been very pleased with it. Some of the earlier ones tended to leak air through the relief valve. Need to air up my hitch before towing. It tends to hold while parked but I guess the motion of towing near the 50# max tends to burp air out the relief valve. Some people have removed the relief valve and reported no more issues. There's no relief valve on suspension (truck) air backs so I'm not sure why they installed on the hitch.
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 23, 2025
