NMDriver wrote:
I have years of experience towing with a gooseneck and a regular hitch. What is your question?
BTW: in spite of what you will read here in a short while from the anti gooseneck people, it is no more likely to damage your frame than any other hitch.
Perhaps you should study the design geometry and gusseting differences between a gooseneck and a 5th wheel. There is a reason that many RV manufactures will void the warranty if you tow with a gooseneck hitch.
That said, there are a couple of adapters that are supposed to be designed to reduce the multiplied torque applied to the 5er through the use of a gooseneck,
