Doc Rose wrote:
Just starting out full time RV living. I have a 2015 Ram turbo diesel 6.7 with a Gooseneck hitch built in. I'm purchasing a toy hauler under 15,000lbs dry. I'd like to use the Gooseneck,pros/cons/ suggestions?
Last two posters gave best answer, I'm in full agreement with them.
It would behoove you also to use the unit's GVW instead of a 'dry weight"...it's far more realistic because no one tows dry or empty..also gives you a better idea of pin weight. (9approx 20% of GVW).
Easiest answer to your question, call the manufacturer of the 5er and ask THEM if they'll
honor their warranty if you tow the 5er with a GN..Just cost a phone call and you get the right answer straight from the horses mouth so to speak. That's pretty much the pro's and con's...If manufacturer states it's ok to use a GN and it won't void some of your warranty, go for it...if they DON'T recommend towing their 5er with a GN, then it's your call and your decision if you want to take a chance with possible frame or delamination issues.
Jim
