Nv_Blu's avatar
Nv_Blu
Got to be a better way.
Having RV'ed for nearly forty years, I've never been totally satisfied with the propane tank procedure. As I get older, those darn tanks seem to get heavier and heavier. The lock down system (wing nuts on all thread) is just not efficient. Has somebody come up with a better solution for filling propane tanks on towables?
  • SDcampowneroperator wrote:
    Under nfpa 58 & 1194reg's, tanks must be mechanically secured. To alter the mfgr design opens you to liability.
    Maybe the op needed to know that, but it don't seem to help him with the original problem......which is how to make his life a little easier(while still toeing the line with lawyers and police).
    I camp in a fiver, so the suggestion to use 20lb tanks instead of 30..is a good one for me since my tanks are secured with bands around the middle of the tanks, and are easily adjusted for smaller tanks. They clamp down with a simple lever which is easily released and reclamped.
    Maybe there is a way to secure the tanks on a travel trailer using that type of band, and in a way that makes all the lawyers and anal people happy.
  • Under nfpa 58 & 1194reg's, tanks must be mechanically secured. To alter the mfgr design opens you to liability.
  • I would say that getting rid of the thirty pounders and going down to the 20 pounders is not going to cause that much hardship. Unless you are winter camping, 20 pounds still lasts a long time.
