rfsod48's avatar
rfsod48
Grab bar
Any ideas on how to install a grab bar in our mh bedroom? The walls that we need it on are thin plywood with no studs in the area. Any ideas or suggestions would be appreciated.
  • I had grab bars installed in our travel trailer for my wife. Our dealer opened the wall and installed additional 2X4 studs in the locations we specified. Gave a good, solid attachment point.
  • When I installed a grab bar in our Class C, I went behind the thin plywood wall and placed a small piece of thicker plywood (or use a regular wood like a piece of 1x4) on the reverse side of the wall directly behind the spot where I wanted to place the grab bar; it was glued to the wall so it wouldn't fall down. Then I screwed the grab bar to the wall using screws that were long enough to attach themselves to the wood behind the wall, but not too long in case you have to reach into the spot for whatever reason and not get scratched. If you cannot place a piece of wood where it won't show, then get a small piece of hardwood and stain/varnish it to match the wall and follow the same procedure.
  • For information only - Not an advert...
    Two alternative styles of grab bars that might work:
    Swing away bed bar.
    Or
    Grab pole
    Both types come in several models. The pole is free standing but can be attached to floor and/or ceiling with some modification.
    Prices and quality vary.
    We got the pole type for my Mother and told her it would double as a stripper pole. (Yes, I fully expect this last bit of information will be moderated out. ;)
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 08, 2026
