Any recommendations on how to get the grease off and out of the gray tank due which results from the cleaning the pots and pans? The residue seems to get clogged in the drains and in the tank?
Wipe out your grease from pots and pans with a paper towel and put it in the trash. Do not put it in your sink!
If you already have a grease issue.... put a generous amount of Dawn dish detergent (best degreaser) down the sink. Follow with HOT water until your gray tank is full. Drive around a while to mix it up. Drain the gray tank and repeat.
Be careful of putting any chemicals in the tank. There are lots of de-greasers out there but some of them might damage the plastics.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
