Any recommendations on how to get the grease off and out of the gray tank due which results from the cleaning the pots and pans? The residue seems to get clogged in the drains and in the tank?
Don't put coffee grounds down there either. Grease, food stuff, coffee grounds and hair. Can you imagine? Also, don't leave your gray valve open all the time. The crud will just lay there and in your hose. Dump when it's full - just like your black tank. It's no big deal to go outside and pull the lever every few days.
We always wiped our dishes with a used paper towel or napkin before washing. Never had any problems or smells in 16 years of full-timing.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
