Downunda's avatar
Downunda
Gray Tank Cleaning
I'm in Australia and have a new Class C, its only taken a little while for the gray tank sensors to foul up. The dealer did a tank clean for me and I had to pay.
I've now bought some drop-in RV tank cleaning tablets and have yet see see if they work at all. However, in the meantime I've been thinking about lower cost ideas that might work as well or better.
The first is perhaps to disolve dishwasher tablets and flush them into the holding tank and drive around with the tank fairly full to loosen stuff up. The other is to make up a solution of bicarbonate of soda and try that.
What do forum members think about these ideas?
  • Thanks, Elomonate is what I have and will try it in the next few days, however at $18 a packet here I don't see it as a long term solution.
    Thanks folks for the other suggestions as well, I wll work my way through them.
    Regards
    Even when you're careful about what you allow to drain into the grey tank it still results in an amazing amount of sludge that will foul the tank sensors. For several years now I've been using Walex Elemonate in my grey tank and am amazed at the amount of stuff that comes out with the water. Here's an Australian source for Elemonate.
  • Yeah, get used to that quality. You're going to see a lot of it.
  • I drop a Dish-washing pod into each tank, before we leave on a trip. Add about 5 gallons of Hot water and by the time we arrive it's usually clean.
  • If you use your rig a lot you will get used to knowing how full they are without the sensors. Also by monitoring the sensors on your fresh water tank. They don't foul. The black and grey do frequently. My personal opinion is its not worth effort. If you equalize your black and grey tanks and they can hold all the water from the fresh tank then there is no issue to begin with. JMHO
  • If you have it, Dawn dish soap followed by lots of water and some water softener like Calgon. Again US products, so they might not be available, but you sure should have something similar.
  • water and soap and drive and soak (for days) then drive then dump
    OR
    if its going to set a while unused, there is a septic tank additive
    that will eat everything clean, but takes a month or so to do the job
    fill with water put in the septic cleaner, drive to stir
    then let it set and digest the waste
    get a power rinser to use while dumping to keep the sensors clean
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 11, 2025
