If you are going to only go by the sticker on the door then yes payload is what will get you.
If you end up with a HD truck then the sticker isn't really an accurate representation of the trucks capabilities. Per my door sticker I have a 2888 payload, but based on a more realistic knowledge of the truck I can load up to ±5200lbs of payload. About 1,000lbs of that is taken up with suspension upgrades, wheel/tire upgrades, filters, hitches, tool box stuff, etc. But I have an honest 4,000lbs I can load into the truck before approaching any self imposed limits.
Golden_HVAC wrote:
The dually versions can carry around 5,000 pounds in most modern trucks, built after 2005. They also have GCVWR that are huge compared to their single rear wheel cousins
Is there a specific model you are talking about? Where does this 2005 number come from? A 2005 Dodge was the same running gear as a 2003 Dodge, which was the same (basically, minor changes) as a 2012.
In 2005 the DRW Ford had a whopping 500lb higher GCWR than a SRW 250 or 250. 500lbs, which was 2% more, is huge?
Up until 2005 DRW vs SRW didn't make a bit of difference on GCWR for Ford, 2009 for Dodge. It wasn't until 2011 that DRW GCWR's starting going well above SRW limits, more than just 500lbs. (Don't know/care about GM.. still don't like IFS).
In 2004 a F-250 had a higher tow rating than a DRW F-350, even thou the DRW could handle about 2,200lbs more payload, on paper. My 2005 Dodge 3500 SRW is rated to tow more than the DRW version.
It's all a paper numbers game on the HD trucks anyhow. A 3500/350 DRW doesn't have any bigger cooling system, brakes, etc than a 2500/250. So from a sustainable power standpoint there is no difference.
I am excited to see all 3, whenever Ford gets on board, using J2807 tow specs. It's been a while since I read it, but DRW's will have bigger tow numbers based on J2807 because their required speed up a grade is lower. I am not sure I agree with that logic, but a DRW is the best way to handle a 30K lb trailer in stock form.
