FAWR and RAWR are not legally binding limits, not sure where you got that (if you have a reference please post, but in hours and hours of reading code it has never been mentioned). There are only a few things legally binding. Tire limits (600lbs/in of width or as stamped in the sidewall), axle limits (not the ones on the door sticker but rather the 20,000lbs per axle limit), and registration.
Yeah ...they are. After 11 straight years and many part time years towing equipment/flatdecks and enclosed trailers commercially per DOT regs for a living and going through dozens of scale houses dot will take the lessor of a GAWR or the tire loads rating. Remember the tires capacity is determined by the trucks GAWR per the FMVSS's.
600 lbs per inch/20k axle load limits are max load limits which has nothing to do with lessor rated trucks.
Many state weight codes may read like this;
MOTOR VEHICLES
WEIGHT, SPEED AND TIRE REGULATIONS
(snip)
49-1001. Allowable gross loads.
(3) In determining the gross weight of a vehicle or the gross weight of any two (2) or more consecutive axles under subsection (1) or (2) or (9) of this section, the total gross weight of the vehicle or combination of vehicles or the gross weight of any two (2) or more consecutive axles shall be the sum of the axle weights.
For the purposes of this chapter the gross weight of a vehicle or the gross weight of any two (2) or more consecutive axles may be determined by accumulatively adding the separate weights of individual axles and tandem axles or groups of axles to determine gross weight.
49-1002. Allowable load per inch width of tire. (1) The maximum allowable load for any vehicle tire operated on any public highway shall not exceed six hundred (600) pounds per inch width of tire and shall not exceed the manufacturer’s load rating, whichever is less."
Your 2003 has RAWR and FAWR, so why do you say after 2005? The older trucks I have looked at, from the 90's, have FAWR and RAWR. I haven't been around anything recently enough to know on older.
I think you misread what I actually posted which said;
"Many of these rating are not on our older trucks. Rating like GVWR/FAWR/RAWR are placarded on the older and newer trucks. The other numbers were added later ...many after '05."
So, I have found the exact opposite in reading law's about tires and axle ratings. Where did you get your info?
LOL.... you would never make it through the first scale house being above your trucks GAWR or tire load limits. Dot will take the lessor of the two.
I find many state size and weights regs on the net and many from commercial haulers websites.
They can read like this;
17 AAC 25.013. Legal Vehicle Weight (repealed and readopted 4/9/2009
(a) Except as provided in 17 AAC 25.335, the weight of a vehicle or combination of vehicles, including load and equipment, operated or moved on the state highway
system may not exceed a limit set out in this section. If more than one weight limit applies, the most restrictive limitation will be used to determine the maximum allowable weight, as follows:
1. steer axle ......
2. ...550 lb per inch width.....
(3) the weight on any axle may not exceed the manufacturer’s rating;
(snipped)
(4.) single axle/gross/tandam axle combinations/bridge formula/etc
The OP is from Canada. This from one of the provinces:
Size and Weight
Maximum gross weight for tires.
7.15 A person must not, without an overload permit, drive or operate on a highway a vehicle loaded or configured so that the gross weight on a tire exceeds either
(a) the manufacturer's rated capacity for the tire, or
(b) the tire load specified for that vehicle or vehicle combination in Appendix B, C, D, E, F, G, H or I.
Maximum gross weight for axles
7.16 (1) A person must not, without an overload permit, drive or operate on a highway a vehicle loaded or configured so that
(a) the gross weight on an axle exceeds the manufacturer's rated capacity for that axle or for the brake or suspension system with which the axle is equipped,
(snipped for length)
I'm not going to hijack the OPs post farther or get farther into a back and forth with you. You have had a different back ground towing under DOT regulations/scale houses/roadside enforcement than I have. I'll respond to a PM on size and weight regs with ya' if you need.
