Bumpyroad wrote:
yep, I didn't go back and check,but did we ever ask what the wall material was?
bumpy
I'd put my money on vinyl wall covering applied to luan plywood with an acrylic adhesive to be the case.
Add in some humidity, the weight of the item, and a good pothole or two while traveling and...........riiiiiiiipppppppp. Had it happen and tear the paper starting at the command strip down to the counter 2' below. I can however say the command strip worked well and did not release from the wallpaper during the process. I tried to obtain material to match from Keystone at the time with no luck. You would have to get the matching paper to repair from the manufacturer of the panels. Keystone could not even obtain the 1" wide seam tape they use over the panel joints to match the 2 yr old wallpaper.
