- 1L243Explorer II
dedmiston wrote:
With just one bed, do you even raise it? Is it in a location that you use for something else?
I'm not trying to imply anything, I'm just curious.
We have dual queen happijac beds in the garage of our toy hauler, and we raise the beds so we can use the garage for transporting our off-road car.
I'm trying to picture the purpose of a single happijac bed if it isn't in a toy hauler.
My concern was that the pins might have something with securing the Happijac bed when in transport mode.
This is a Toy Hauler. I actually don't even use the Happijac bed except for storage. It is up all the time.
I'm glad I have it just incase we have a guest.
It is a enclosed garage that has two Jacknife couches that are bolted to the wall and fold up for toys. I use the couches with center table all the time when the Harely is out. - wing_zealotExplorer
dedmiston wrote:
Mines not a toy hauler, it’s a bunkhouse. Raise the beds and load the bikes ( or whatever) through the bike door. Take the bikes out and lower the beds and it’s back to a bunkhouse.
I'm trying to picture the purpose of a single happijac bed if it isn't in a toy hauler. - dedmistonModeratorWith just one bed, do you even raise it? Is it in a location that you use for something else?
I'm trying to picture the purpose of a single happijac bed if it isn't in a toy hauler. - momentum_rvExplorer
1L243 wrote:
Mine only has one bed?
Then use the pins to take load off of chains while on the road in up position. - 1L243Explorer IIMine only has one bed?
- dedmistonModeratorBTW - I always pin my upper bed up while we travel so that the weight is on the pins and not on the chains.
- dedmistonModeratorDoes your lower bed fold into a dinette? If so, you pin the upper bed to the highest position and then lower the lower bed down so you can sit there.
- wing_zealotExplorerYou can pin the upper bed then just lower the bottom (if for instance you only needed one bed). Or pin either bed anywhere you want along the track for whatever reason. I've sometimes stored stuff under the lower bed and put the pins in so I didn't accidentally lower the bottom bed to far.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
