Carrier wrote:
dodge guy wrote:
They don`t make an "D" or "E" rated LT tire in a 15". I went with Carlisle ST "E" rated tires. very glad I did despite what people post about them. all the failures in my research were in the "C" rated tires.
With the E tires what pressure do you have in them? If you went from C to E tires did you find the trailer has less sway?
I run 75 psi with a 9200lb loaded trailer weight. the trailer came with cheapo "D" rated Chinese tires, the trailer has an 11,200lb GVWR! cant believe they put "D" tires on something like that. and yes my rims are rated to 80psi and are 6 lug.
And yes, I had some sway, that almost disappeared with the new tires.
