Rustycamperpant
Aug 19, 2016Explorer
eDUBz wrote:
Wet sand with 1500 and then polish with 3M compound. If you don't want to buy new lens take it to a body shop and have them clear coat the lenses. what ever you do it won't last a long time but will look good. Clear coating will be your cheapest option that will last the longest other than replacing them.
^ This X2, you need to remove the old clear coat that is on the lens with the wet paper going to finer grits as the old stuff is removed. I ended up with 2,000 wet paper. Tape off the area around the lens and use a rattle can of clear coat to finish it up. This will last a long time, I did my DW '03 Beemer two years ago and it still looks great.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
