DrewE
Jan 15, 2016Explorer III
If it's merely cool, 30's or higher, I'd use the fireplace (preferably on low) or the furnace, or just leave everything off and warm things up when I got back. (Technically, I wouldn't use the fireplace in my RV because I don't happen to have one, but if I did I would.)
If it's cold, say much below 30°, on my motorhome at least I'd use the furnace so the wet bay with the holding tanks gets a little heat piped into it.
If not on electric, the furnace is of course the only viable option.
I would not leave a portable space heater unattended if I could help it, and if there were no way around it I'd leave it on low rather than high. Yes, the fireplace is just a space heater with a light show, but it at least cannot tip over, is mounted such that it's not dangerously close to combustibles, and presumably the wiring for it has been verified to be solid and tight.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
