rk911's avatar
rk911
Heated Mattress Pad
Considering adding a heated mattress pad to our IdealRest air bed in our Itasca Suncruiser. is anyone using one? any problems? can't imagine there would be any adverse issues using a heated mattress pad on an air mattress but thought i'd ask before pulling the trigger. any recommendations? looking at a dual-control model.
https://www.amazon.com/dp/B004P4CZLE/ref=cm_sw_r_em_tai_c_yHy.DbY24HDH5
  • I would not use a heated mattress cover/pad on any inflated mattress
    Heat is going to make the air expand,
    The mattress might get more firm than your setting
    It might even start leaking at some seam or seal
    From over expansion
    If somebody does this successfully on a regular basis
    Maybe the will chime in
