- kelly94942ExplorerYup, that's what we did when we full timed, heat tape from the hardware store, wrapped with foam tube. Never froze!
- topjimmyExplorerIf you are going Fulltime like I have the past 3 years you gotta have a heated hose or you can do like i do and go the cheaper route and get heat TAPE at the hardware store I think it cost me about 25 bucks and i also put foam tube wrapped around the hose also WORKS PERFECT and i have never had a frozen hose.I do not like traveling around with a full tank of fresh water it is just too much weight but that is a option to run just off the inboard tank when it gets cold
- pianotunaNomad IIIHi,
Probably better to run on tank water. The hoses are expensive. - Put "heated water hose" into amazon
- WoodGlueExplorerI think there are only 2 mfgs making them. If I recall correctly, Amazon carries one brand and Camping World carries the other Brand.
WoodGlue - ROADSTARJRExplorerThanks' But Who has the best ones?
- old_guyExplorerbuy only the length you need. they are very expensive
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
