ROADSTARJR's avatar
ROADSTARJR
Heated Water Hose
I'm looking at going full time and want to get a heated water hose, would like to know the best?
  • Yup, that's what we did when we full timed, heat tape from the hardware store, wrapped with foam tube. Never froze!
  • If you are going Fulltime like I have the past 3 years you gotta have a heated hose or you can do like i do and go the cheaper route and get heat TAPE at the hardware store I think it cost me about 25 bucks and i also put foam tube wrapped around the hose also WORKS PERFECT and i have never had a frozen hose.I do not like traveling around with a full tank of fresh water it is just too much weight but that is a option to run just off the inboard tank when it gets cold
  • Hi,
    Probably better to run on tank water. The hoses are expensive.
  • I think there are only 2 mfgs making them. If I recall correctly, Amazon carries one brand and Camping World carries the other Brand.
    WoodGlue
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
