I have a 2018 Chev. Equinox premier every time when I tow 4 wheels down the battery goes dead. What am I doing wrong? No braking system attached,and a hot wire going from the coach to the battery wit...
Does the owners manual require you to leave it in the ACC Position? That will kill the battery in a heart beat. Do you have 13+ volts on the Equinox Battery when hooked up to the coach? If the charging line is hooked up properly and powered, you should have 13+ volts on the battery with the coach engine running.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
