Goldgrits's avatar
Goldgrits
HELP! Black tank spill inside
Two days ago I overflowed the toilet on my small black water tank on the second flush of the tank. Water was mostly clean but still black water. I cleaned and sanitized everything I could see.
I took off a panel in the kitchen wall and have noticed moisture under the plastic sheeting that is behind the toilet and under the kitchen area.
How do I get to the rest of the moisture to clean.
The motor home was not level so the flow went from the middle located toilet through the kitchen area then out the drivers side front. Only two basement areas has moisture.
Help help help. New 2018 Winnebago.
Goldgrits is online now
Cross posted in in Irv2
  • X2. The more fans the better. Open up walls, floors as best you can.
  • In addition to manually drying everything the best you can, I'd suggest using a high-velocity, squirrel cage fan to air out the moist areas as much as possible---especially the basement area.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
