tktimmons's avatar
tktimmons
HELP! Cargo door lift arm
HELP! One of my lift arms on my cargo door ripped off from the door. I went and bought a new one, but it will not compress down. I was able to get it on the door and camper, but the cargo door will not shut. The arm will not compress. What am i doing wrong?
Thx!!
  • Dont'think so. It isn't marked on the spring itself, but the old one was labelled 80lb
  • Gas springs are spec'd by length and weight - you didn't get a 90-pound strut when you were looking for a 30-pound one, did you?
  • Doesn't compress it all. Even just holding it here in my hands, after removing from the camper, it won't compress. When i bought it at the store, i checked all they had on the shelf, and none of them compressed. The lady said it would compress once i mounted it, but it doesn't, unless i'm doing something wrong. Why would the arm not compress now, with me just holding it here off the camper?
  • Will not compress at all? Of just not enough? Sounds like it may not be the same travel length as the old one.
    Oops. I was a minute late. Sounds like a bad ( or maybe stuck) strut.
  • Yes it is the same size. I took it off and holding here in my hands, and i cannot even get the arm to compress down.
  • Did you get the right size? Is it attached exactly the same way as the other one? I seem to recall taking my bed apart and couldn't get the arms to compress after reassembly because one of the mounts was slightly out of position.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
