camper_don
Mar 10, 2016Explorer
HELP! Did I buy a trailer that I can't pull????
I understand that just asking this question really shines a light on how much of an idiot I am. That being said, I'm going to ask anyways. I started shopping for my first travel trailer a few months ago and have been told by dealer after dealer that towing a sub 5000lb GVWR trailer would be no problem with my 2011 Chevy suburban. Well, I went ahead and ordered a new 2016 starcraft ar-one maxx 19bhle through camping world
I put a down payment on it since there were non around and it should be here in about 8 weeks.
So, I've been reading up on the different hitches and am getting concerned about a lot of forums that go over so many different TT and TV weights. I thought that I had plenty of towing capacity but now I'm just not sure. I know there are a lot of posts up there that talk about this, but I'm hoping that some of you with years of experience can chime in on my exact setup.
Here are the weights on the trailer:
Weights
Unloaded Vehicle Weight (lbs) 3,373
Dry Hitch Weight (lbs) 400
Gross Vehicle Weight Rating (lbs) 4,400
Cargo Carrying Capacity (lbs) 987
Fresh water capacity is 42Gal.
My tow vehicle is a 2011 chevy suburban 1500 LT 4WD.
Here are the specs I pulled off the door:
GVWR = 7400lbs
GAWR FRT = 3600lbs
GAWR RR = 4200lbs
According the manual, I have the following towing specs:
Max trailer weight = either 5000lbs or 5500lbs(not sure if my model is LC9 or not)
GCWR = either 11000lbs or 11500lbs (again, not sure if I have LC9 model of suburban)
max tongue weight is 1100lbs
I don't know what the curb weight or dry weight is of my Suburban.
I don't even think that I can get my deposit back if it is too heavy but maybe I can put it towards something smaller if not:(
Any help is very appreciated.
Thank you,
Don
Weights
GVWR = 7400lbs
GAWR FRT = 3600lbs
GAWR RR = 4200lbs
Thank you,
Don
