Leichardti
May 11, 2017Explorer III
I believe the issues was were the wire connect at the first brake drum. It gained connectivity when I wiggled the crimp cap around. I will replace the cap/connection there.
Everything else looks good but There seems to be moisture in my axle, I can see it when i pull out the wire a little bit.
Over the next few weeks i'm going to replace all the fuses, circuit breakers, connectors, service wires under drums and at least replace the wires going thru the axles.
A portion of the brake wiring is well insulated, it kind of looks like romex. Does anyone know where I can buy it or wiring that has heavy insulation?
Thank you for your time.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
