pnichols wrote:
Veebyes wrote:
Of course if you are a certain distance offshore you can simply pump it out yourself. Everything else living poops into the ocean.
Ugh, ugh, ugh ... but everything else living in the ocean does not use TP after they poop. :S
As a lifelong waterman that used to liveaboard, I can tell you that the paper is just a non-issue. Back in the days before holding tanks or even macerator pumps, it was not uncommon to see little brown balls floating in the harbors. This is why we never swam in the harbors. Cities did no better. As a student a the Maritime College, we frequently saw "Bronx Whitefish" in the ebbing tide, but no paper was seen.
Matt
