itguy08
Nov 01, 2017Explorer
BenK wrote:
I'm talking MTWR...you are talking payload. Apples to oranges...but inter-related...as all ratings play in the ratings system
Yes, and the Maximum Tow Rating is calculated based on the GVWR, axle ratings, and payload.
Best if we had the actual weight of your TV. Both empty and fully (people, cargo, etc) loaded ready to tow...in order to validate my numbers using the below charts...as half tons do weigh less and if yours has the aluminum sheetmetal...it just might actually weigh in at 5,900 lbs with all of the options (not a stripper model)
You don't need to know that - the manufacturer has done most of the math for you with the payload numbers. The payload sticker on the door jamb is specific to that vehicle as it left the factory. It takes into account all the factory installed options and a full tank of gas (but no driver).
Here's the actual stickers off my door jamb:
Ford certified the truck with a GVWR of 7650, including the 1820 lbs of payload. That means as it left the factory, the truck weighed 5,830 lbs with a full tank of gas.
Since I have the Max Tow package the hitch is rated to 1130 lbs of tongue weight (I think but it's 10% of 11,300 from what I remember the last time I looked) so, yes I could come very close to the maximum the brochure says it can tow.
This is no mythical vehicle - you can walk into any Ford dealer any day of the week and order one in a similar configuration. I'm sure the other manufacturers offer similar configurations and play by simlar rules as tow ratings are pretty much standardized now. Problem is not all vehicles are configured alike and you sure could get one that looks just like mine with much less capabilities. People will see those huge #'s and think all the models will do it, but it's often an option or a few specific models.
The best thing for the OP to do is get GM's manuals on towing, look at the #s on the door jamb, and most importantly the window sticker to determine what packages it has. It may not have the towing package so it may not be able to tow much. Or it may have a maximum towing package. Or something inbetween.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
