richnorsworthy
Mar 30, 2015Explorer
We purchased a 2014 Jeep Cherokee to tow behind our MH. We are having problems with is swaying if we hit a rough spot in the road. It really is so bad we have to completely stop and start over. I have also talked to another 2014 Jeep Cherokee owner that has encountered the same swaying issue. This has only happened at slower speeds so far. The swaying is bad it would cause the MH to wreck if it happened at higher speeds. The dealer has realigned every thing, when we towed over the same rough roads it still swayed, but not as bad. We are sure we want to tow it on a long trip. Dealer even said that they did not think the realignment would keep it from swaying. This is a safety concern. We are no sure what to do. When we tow my flat bottom boat or a trailer, the transmission shifting is very rough. Also, be sure you watch out for the electronic parking brake it comes on at strange times. It towing it you will damage your rear tires.
Looking for advice before your next adventure? Look no further.25,173 PostsLatest Activity: Oct 26, 2025
