outdoorlovers's avatar
Nov 03, 2013
Help! My bed is stuck in the open position.
New Jayco FW - opened up bed to store something and now it won't close. Feeling stupid. Any suggestions.
  • OK reread....thought you had a bedroom slide stuck open :S
    Just push down hard on the bed.
    Those gas struts can be very difficult to start closing when fully open
  • sounds like a bad strut .... they are pretty easy to remove but be careful and don't allow the bed to fall on you
    Jim
  • Does it even try or nothing at all?
    Battery low voltage
    Slide out relay/fuse bad
    Bad switch....loose connections
    Obstacle blocking slide out
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 18, 2025
