vlopddap
Jun 02, 2014Explorer
Fastfwd75 wrote:vlopddap wrote:
the rear on my van sag 50% more than front (and from increase a little bit) with the WD hitch install.
What are the numbers for sag front and rear? Front should not sag at all. It should be higher or equal with or without the WD hitch.
Front: In the manual's example front is 28" empty, 30" without WD and anything between 28-29" with WD is OK. Front still going up but not as much as without. This is how you know how much weight is transferred.
Rear: 29" unloaded, 26" loaded and 28" loaded with WD. This number should be more than without WD but still less than unloaded. Rear end still sags; not as much.
I didn't take accurate measurement yet, but visually the front end is about the same (no sag at all), but rear is 50% lower than unloaded.
When completely unloaded the Caravan front and rear are perfectly levelled BTW.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
