Fastfwd75
Jun 02, 2014Explorer
vlopddap wrote:
I didn't take accurate measurement yet, but visually the front end is about the same (no sag at all), but rear is 50% lower than unloaded.
When completely unloaded the Caravan front and rear are perfectly levelled BTW.
Try to compare loaded without bars and loaded with bars. Measure to see if the rear gets lower when you remove the bars. If it does you know that at least some weight is getting transferred to the front. To get the perfect adjustment you will need to follow all the steps in the manual and measurements are a big part of it.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
