vlopddap
Jun 10, 2014Explorer
Here's the first try on readjusting my Equal-i-zer WD hitch. I add one more washer, but as I told my washer are slightly thicker than the factory washers, not twice thicker, but I would says 1.5x thicker. So the count is now 5 factory washers + 1 thicker washer.
IMO the rear end is still sag a little bit and front raise a little bit. But I don't know if I can adjust it better than that...
What is your opinion? Is this adjustment good enough or you would try an additional washer on the WD hitch shank?
Moderator edit to re-size pictures to forum limit of 640px maximum width.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
