Ron_Gratz
Jul 21, 2013Explorer
daystrom wrote:
As far as the weight distribution goes, I've played with lowering the L brackets and removing washers. No matter what I do the spring bars seem loose and don't seem to be moving much weight around.
Ron3rd wrote:Todd, I think you missed what Ron3rd said.
To increase WD you need to add washers to increase the tilt on the head, and/or raise the L brackets, not lower them. Your moves have had the opposite effect if you removed washers (decreased tilt in the head) and lowered the L brackets.
You need to add washers and/or raise the L-brackets to increase load transfer.
Ron
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
