I am shopping for Tow Bar and want to make sure I am buying the correct thing. There are some that look like they attach to a hitch but what I need to attach to MH is NOT that. Is this correct? ...
Number three is harder to hook up as you must be aligned correctly and right distance. Number two needs to be inspected for cracks at the slip joint and normally needed to have slip joints cleaned. You can normally check under the boots. It looks good. Number one is or would be my first choice.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 17, 2026
