mowermech
Sep 05, 2020Explorer II
The transfer case, when in Neutral, will make a little noise when the transmission is in gear with the engine running. That is normal. Any gear grinding noise is not normal. It may mean that regardless of what the computer says, the T-case is not fully in Neutral. This could possibly be a linkage problem.
IMO, you should take it to the dealer and show a mechanic what is going on; set the parking brake, put the T-case in neutral, and with the engine running put the tranny in Drive, let the mechanic (technician) listen to the noise you are hearing. Insist on a mechanic, not the service department counter clerk!
It is quite likely you will find that the noise is nothing to worry about.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
