mowermech
Sep 05, 2020Explorer II
When I unhook my Jeep from the motorhome, the first thing I do is unlock the doors, put the transfer case back in High Range, and the transmission in First Gear. THEN, and only then, will I unhook the towbar.
I don't even use the parking brake when hooking up. Connect the towbar, put the transfer case in Neutral, the transmission in 6th gear, set the ignition switch, and lock the doors. I never have to worry about not releasing the parking brake, because it isn't set to begin with!
It works for me, you do what is right for you.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
