Grit_dog
Sep 08, 2020Trailblazer
DallasSteve wrote:
That sounds like a good plan. I'm also concerned I might forget the parking brake and tow the Jeep with the brake on. My parking brake seems to be very strong so I would probably notice, but you never know.
Be careful. I sense a TON of apprehension in every post of yours.
On another note, not sure who "they" are, but NEVER try to shift a transmission out of park or neutral while the t-case is in neutral and engine running.
If Auto Park was trying to grind the trans into park with the door open that is a horrible feature.
You can disable auto park a few ways. 1 tuner to remove the feature. 2. Just have the drivers seat belt buckled (it will override autopark if you open the door in gear). 3. Unplug the door power connection (like you're removing the doors). 4. It is automatically disabled when in 4 lo.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
