hammer21661
Mar 14, 2014Explorer
TucsonJim wrote:Or of you need to get it on and off use 3/16 aluminum and tap each side for a machine screw every 6 inches and insert it with lock tite. So, you stagger the holes side to side every three inches in the aluminum. Then drill corresponding holes in the liner put the aluminum on the inside with the screws sticking down and put on the lock nuts with big washers. so you can remove it easily if you have to get back in there.
One possibility would be to take a 2 inch wide piece of aluminum strip. Cut it to length, and then pop-rivet every few inches on both sides of the cut.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
